Help me identify this engine!
This topic is closed.
    Whats up guys. Found a wrecked cb7 up the road from me. My engine is pretty much done (burns oil, leaks) So I asked her how it ran. Started and ran great. Trouble is, when I popped the hood, I saw this engine. I asked her if it was the stock engine, and she said yes it was, so not wanting me to give anything away, I agreed.
    So what is this engine, I know its a 2.2. Im pretty sure its an f22, but is it some special variant? What are the specs on this, and is it better than my stock f22?
    Thanks!
    looks like a f22b
    H22A Vigor
    SR20 Accord
      Yep F22B.
      Basically it is a twincam version of the F22A.
      Refer here - http://www.cb7tuner.com/vbb/showthread.php?t=41915
      My 5.7 LS1 Holden Ute
        thanks guys. It looks like it will bolt right into my accord. Im going to pick the car up then, she only wants $500 bucks for it.
          men i miss that motor f22bdohc that was my frist engine before i got a h22
          92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
          91 cb9 wagon
            how did you like it? Did you have an f22a before the f22b?
              i had a f22a1 with 380k miles on it and then i got a f22bdohc and i just love it it just fell like it want to keep on pulling in every gear
              91 cb9 wagon
                Thanks man, ill deffinently throw this motor in then
                  gotta say i love mine...when i had my h22 i loved it till....i got this one and its just a monster!!!iv even beaten a few h22 accords...gsr/type r bubbles no problem!
                  my new turbo build
                    It could also be a non-VTEC H23 or F20A SOHC or DOHC.
                    F22A* are the stock engines that come in North American CB's.
                    Just check the engine code on the block, it's near the upper radiator hose connector on the engine, and look down and you'll see what it is.
                    Current:
                    2007 Acura TL Type-S 6MT KBP
                    Past:
                    1992 Honda Accord EX-R Sedan - RIP
                    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
                    Words change lives. You just got to choose the right ones.
                    Instagram: @CB7Nub
                    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
                      It kinda looks like a USDM H23 to me. I think I see a coil wire coming off the distributor. Aren't the JDM F22A/22B DOHCs Internal coil? Unless the person that swapped the motor kept the usdm distributor.
                      But yeah... just look at the Engine code right next to the flywheel timing rubber plug thats right under the upper radiator hose and it will be a dead giveaway.
                      I am the Yakuza CB7!
                      JDM 96spec H22A 178HP 149TQ
                      "The JDM Fleet"
                      1993 Accord Sedan - 2.2 JDM H22a
                      1994 Prelude V-Tec
                      1999 CL 3.0
                      2000 Prelude
                      2010 Accord Crosstour - 3.5
                      1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.5
                      1994 Mirage S Sedan - 1.5
                      1991 Isuzu Impulse RS - 1.6 AWD Turbo
                      1993 Asuna - 1.8 "CDM Impulse XS"
                      1993 Sentra SE-R - 2.0 SR20de
                      1995 200sx SE-R - 2.0 Sr20ve
                        Take a picture of the engine code; that will give us an idea if it's a G Series or not. Could be just a JDM F22B DOHC, H23A1, or the above.
                        Originally posted by toycar
                        Braking the bank, maybe. Feeling like a boss, likely.
                          Yes they are internal
                          Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
                            There is no such thing as a g series honda accord nor prelude motor kiddo.
                              The G series was the 5 cylinder. There was a G20 and a G25. If it's got 4 spark plugs, it isn't a G series.
                              G20A
                              Displacement: 1,996 cc (121.8 cu in)
                              Bore: 82.0 mm (3.23 in)
                              Stroke: 85.6 mm (3.37 in)
                              Compression ratio: 9.3:1
                              Max Power: 158 hp @ 6700 rpm
                              Max Torque: 137 ft·lbf (186 N·m) @4000
                              Found in the 1989-1991 JDM Inspire/Vigor (CB5), 1992-1994 JDM Inspire/Vigor 20 (CC3), 1993-1997 JDM Ascot/Ra***a 2.0 (CE4), and 1995-1997 JDM Inspire/Saber 20 (UA1).
                              G25A
                              Displacement: 2,451 cc (149.6 cu in)
                              Bore: 85.0 mm (3.35 in)
                              Stroke: 86.4 mm (3.40 in)
                              Max Power: 177.5 hp (131 kW) @ 6500 rpm
                              Max Torque: 166 ft·lbf (225 N·m) @3800
                              Redline: 6800 rpm
                              Fuel Cutoff: 7100 rpm
                              Found in the 1992-1994 JDM Inspire/Vigor 25 (CC2), 1993-1997 Ascot/Ra***a 2.5S (CE5), and 1995-1997 JDM Inspire/Saber 25 (UA2).
                              G25A1
                              Compression ratio: 9.0:1
                              Found in the 1992-1994 USDM & CDM Acura Vigor (CC2).
                              G25A4
                              Compression ratio: 9.6:1
                              Found in the 1995-1998 USDM & CDM Acura 2.5TL (UA2).
                              Originally posted by Junior Smurff
                              Nevermind guys, google search works wonders!
                              I don't have road rage, my car just goes faster than yours!
                              Accords are for winners. And Grandmothers. But mostly winners.
                              I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
