okay well the f22ax's water pump will NOT work too for the f22b because the f22ax has 20 teeth and the f22b and h23 only has 19 teeth so i'm going to have too special order one from Japan.
special order one?? boy are u crazy.. lol.. how do u think ppl with their f22bs get water-pumps changed?? the 1tooth difference wont matter it will just make the waterpump spin a lil faster nothing drastic.. if ur THAT ANAL about the 1 tooth u can get a pulley puller and pull the gear off the f22b pump and put it on the f22a1 NEW pump.. but yeah.. using the f22a pump with 1 tooth less is nothing OMG lol.. just make sure u set the timing belt correctly and shell be fine..
