Hello everyone,
I'm poppin my cherry with this post, let me tell you whats up...
I appreciate your time in advance, so thank you!
I just picked up a 90 Accord Coupe with an H22A swap a couple days ago and now I'm fixing it up and getting it roadworthy. Whoever did my swap was a hack and now I'm going through the car and cleaning up the last owners mistakes. For starters, the distributor & parts of the ecu were wired up by twisting wires together and electrical tape
I bought this front end damaged 1990 Accord DX Coupe for $1200 with tokico blue struts, clean title, 230k chassis mi, konig 16's, and a h22a with aftermarket lsd.
Heres its problems, as I mentioned many things on this car are horribly installed, I have spent the last three days fixing the previous two owners mistakes and turning it into a real car (that means taking out all of the ORANGE GLOSS ENAMEL! painted interior pieces and painting them flat black (until I can find clean oem replacements)) properly wiring everything up / and installing a new bump support / rad supp / headlights / hood / grill / and radiator...
Anyhoo, when I got the car It ran like shit (the guy I got it from said it's throwing a cel for tps) idled at 2500rpms and felt like shit when I drove it home, if i gave it full throttle it bogged out, since I got it home I replaced the plugs as well as ran a compression check which came out as follows:
200 190 135 200
4 3 2 1
I squirted oil into #2 and brought it up to 195 so I have bad rings in that cyl (right?). After running the comp check (and checking the fuel filter) the engine now dips and won't idle even at all it just constantly 'hunts' - I think the TPS is bad.... If you give the car approx 35% throttle or more it is fine, less and it jerks and splutters all over the place.
After setting the TPS (it was at .52) back down to .45 & hooking up the vtec / oil press / intake air sens it brought the idle down to 1000-1500 rpms (constantly jumping remember)
I should mention that none of the swap / vtec wiring was hooked up so I hooked up everything but the knock sensor which brings me to one of the main goals of this post, my knock sensor has no pigtail so what model year & car type can I find a corresponding harness off of so I can finish getting it hooked up. Just by hooking up the three out of four wires (oil press, vtec, air) the car feels A LOT better and has MUCH MORE POWER I will check the cel codes tomorrow (just found the resources on the board to check it out)
So I just wanted to get some experienced tuners input as where to go from here, as of now my to-do list is:
1.) check cel codes
2.) get tps
3.) get knock sensor harness (dont know where though...)
4.) replace valve cover gasket and Front Main Seal
5.) replace p/s pump (it makes a horrible groaning noise, belt adj didnt help)
anything else I should do?
thank you all so much for taking the time to read this
Chris 'Brains'
200 190 135 200
4 3 2 1
1.) check cel codes
2.) get tps
Chris 'Brains'
