Prelude power steering line
    Is it just the metal line / fitting that makes it not work or is the accord shorter then the prelude line? If its nothing more then the metal part then yea im gonna get it just reconnected at my local napa/machine shop... If the PS lines are different lenghts then im gonna just order one. Damn... stopped into my local honda, they want $180 online at conicelli and a few other places its $120
    **My CB7 has been sold**
      they just run different, its weird put them up next to each other and you can tell, they have different angles ... just to be on the safe side of the h22 fitting comes with a lil extra hose, add a little extra hose to your f22a one.. its all gravey baby!
      do what you gotta do!
        Ok problem solved... just found and ordered one from a respectable online Junkyard. H22 Vtec motor! Just need to get the Front crossmember and it should all be set to go back into the car...
          i have done it for my f22b you have to bend th shit out of the hose that goes to the rack it. i got my hose brand new from www.partsamerica.com for 83 bucks
          cb7 sold
          2002 mineral gray mustang gt not stock
          95 accord lx daily driver
            damn... wish i would have known about that yesterday! Oh well mine is on the way but thanks for the response.
              Guys... ive heard that i had to use the Ps pump off the f22 or get and get a PS high press. hose to make it all work.... id just like to let all know.. and ill post pix after its all done.. but in my F22B swap i used the F22a PS pump and bracket... yes the two right mount spots fit the one left doesnt cause its too far over... and the bottom of the right two is inset... Ok get a spacer on the bottom and it holds tight even with out the left one on.. Personaly mine is going to the fab shop and im getting the left side cut off and either left alone at that or the end of the tab welded back on closer in... like i said when im done ill post pix of what im talkin bout...
              just thought id say cuase i was told it wouldnt work
              . . .93 Ex F2.0A Si. . .
              WiredMotorSports
                of course,there is a little rub on the hood.. yes it clears but under torque the lift makes the front pressure hose bolt and a lil place on the metal part of the hose touch hood... but then again my torq. mount is shit maybe thats y it hits... but even if it was good the space is only like 2mm. and would probly still hit with flex... im going threw a few diff. ideas.. ill post later what i figure out... lol
                WiredMotorSports
                  The H22 and H23 power steering lines are the same. I have an H23 for my motor, but I don't really feel like putting the PS back on cuz it's nice driving without it.
                  I just bought it cuz it was only $50 shipped and just in case I want to add power steering.
                  The Accord pump sat too high for my hood and all that.. so I used the Prelude pump.
