So i recently bought another cb7.
The previous owner had swapped a jdm h22a into it.
Also with a jdm p13 ecu.
It came with a few problems.
The CEL has been on, i ran the codes and they came up as a MAP sensor code and a VTEC spool solenoid valve code.
The symptoms i have been experiencing:
-no vtec (from what i can here)
-6500 rpm rev limit.
-car dies if i start it and dont rev it up immediately.
-car struggles a little while the rpms are under like 2000.
-when reved up the rpms drop REALLY low (almost dies but recovers)
I changed the oil a few days ago, with no difference.
I have taken a few pictures of some things that kinda concern me and might be the cause of my problems.
It is wired for vtec from what i can see (not the safest thing with house wiring connectors, i plan on soldering everything soon lol)
I followed the three wires back to the ecu and this is what they look like.
For some reason the dark green one is running into this extra harness with the black connector on the end. Does anyone know what that is for? Maybe that is why my vtec isnt engaging? The light purple one is running to a little green/yellow wire that goes to the ecu. And the see through dark purple one doesnt run to anything.
And im not sure why but it has the stock accord map sensor.
It also looks like it has a stock accord throttle body as well.
Is this why im getting the map sensor code?
And yes i have been searching and searching and havent found much that could help.
So i would really appreciate it if someone could help.
Please and thank you lol.
