5 cylinder CB7?
    5 cylinder CB7?
    I was watching an old top gear episode when I heard that in Japan the cb7 came with a 5 cylinder option. Has anyone ever seen or even heard of this?
    IT IS WHAT IT IS
    The old 2nd and 3rd gen Accords in Japan also had a pretty much identical version called the Vigor. The next gen Vigor with the 5 cylinder engine (same as USDM) looks totally different from the Accord but had the chassis code cb5 so it's kind of still in the Accord family.
    JDM 2nd gen Vigor (CA-3)
    http://www.honda.co.jp/auto-archive/vigor/1989/
    JDM 3rd gen Vigor with 5 cylinder engine (CB5)
    http://www.honda.co.jp/auto-archive/vigor/1991/
      Yes, also known as the Accord Inspire in Japan. Many of the parts do interchange, I have a Vigor rear sway bar on my wagon and it bolted right on
      1992 Accord Wagon (RETIRED)
        They carry quite a few parts that fit on our CB's as well (IE they have the same part number for front brake calipers (CB9, BB1, BB4 to name a few)). I did some reading about the Vigor and was curious about it (but sadly not much aftermarket for it engine wise that is.) My two cents.
        The CB7 Collector.
        92 LX Coupe F22A1
        2013 Toyota Corolla S
        92 EX Sedan F22A1
          the engine and tranny are mounted north-south and it has a weird transmission with a seperate diff like the legeneds my guess would not be worth the work unlees you wanted cool points for being different the engine was rated at 176hp you might as well just buy a vigor instead of going trough the hassle to turn a cb7 into a cb5 vigor lots of work just to look like a different car you can already buy just my opinion
          current cb 93 10th ann. edition
          member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
