H22A swap
    H22A swap
    what's up every one....how you doing???
    i wanna ask about the h22 swap....i got 1992 CB7 imported from USA.....i wanna to change the F20A with a 1996 H22A...what are the modification i need to do in order to fit it under my hood....HELP
    Check out my RiDE...
    http://www.cardomain.com/id/oj_low
    Search around a bit bro, its super straight forward.
    To sum it up...
    -It uses the stock mounts and axels
    -Use the stock wiring harness
    -You need to add 5 wires into the harness
    Thats it, its the most straight forward Honda swap out there.
      ya, the h22 is very straight forward.
      i've found three things to be extreamly helpful.
      1) H22 FAQ - http://www.cb7tuner.com/vbb/showthre...&threadid=5423
      2) F22 removal (probably same for F20) - http://www.cb7tuner.com/vbb/showthre...&threadid=8849
      3) A manual, im poor as i'm saving $$ for the swap because I need a 5sp tranny So I need the expensive FULLSWAP 2.4grand after shipping. I got the HAYNES 90-93 Accord manual. lots of good info, easy to read.
      As cb7deathride said, please...save everyone the time and use the search button.
      Thanks
      2DAO (2 Door Accord Owner)
      JDM H22 DOHC 200/161 2.2L
      My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
