A quick question
    A quick question
    I'm in the process of doing a auto to manual swap and noticed that there is a plug (I don't know what it is called) on the manual tranny where there isn't one on the auto tranny.
    I have a picture to show what I'm talking about. It does have two plugs at the end of the wire.
    Here is the question:
    Do I need it? If I do need it, will I have to change the harness since it seems to connect to the harness?
    I did some research about doing a auto to manual conversion and probably forgot or might have missed this part.
    It is a sensor for the reverse gear. Yes you need it.
    FOR SALE on cb7tuner only for now. Want it in the right hands
    Pm meX
    I do swaps in NYC/LI area: Hit me up for a quote.
    MY WHIP
    H22A Swap
    I'm 'THE STIG'
      if its not on then your reverse lights wont work.
        Thanks to the both of you.
        So now I know that it's a sensor for the reverse gear.
        So where does it connect to?
          Check the *Sticky* thread on manual trans swap should be in the swap section. It should go from tranny to shift console. Has to be wired up to a set of wires in there. I forgot which ones.
          Pm meX
          MY WHIP
          H22A Swap
          I'm 'THE STIG'
