h22 wiring
    h22 wiring
    ok so i couldnt do the swap my self and my friends dad is doing but he not sure how go about wiring the motor to my cars wiring harness i know may sound dumb for asking but is there anywhere i can find a step by step way to wire up my h22 ? its a (jdm h22) how do u guys go about connecting the wiring harness the plugs dont mach up right?
    Wiring
    Almost all the plugs cross over. You will have an extra one for coolant temp, but other then that it literally requires you to take the harness off of the f22 and put it on the h22, then plug it in like you would an f22.
    You will have to add the wiring for v-tech, knock sensor and the wiring for the IAB's but those are easy and covered in the swap guide.
    It is really the easiest swap you can do for our chassis.
    The only other issue you could have is if you are running an external coil. If you are the conversion for that is also covered in the swap guide.
    Hope that puts your mind at ease. Any mechanic that has a good head on their shoulders can figure it out.
    Give him/her the the site swap guide as a reference and let him/her do it.
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
      Thnx a lot man I was going back fourth on swap thread I found most of it and yea I talked to my homies uncle and he looked at the thread and he said he gets it bu thanx again man
      My car thanks u too
