h22 swap question
    h22 swap question
    so im planning to swp an h22 on my 91 ex im getting the motor from hmotors online i know it fits right in is there any thing i should worry about replacing or changing
    ... cuz from hmotors it comes with all harness,sensors and exhaust manifold
    it might be a good idea to do a timing belt and water pump while the motors out of the car. dropping the oil pan to clean and inspect it cant hurt either.
      ok, heres all i got 2 days ago for my swap:
      14400-P13-014 BELT, TIMING (155YU24 A-555)
      19200-P13-003 WATER PUMP (YAMADA)
      30110-PA1-732 O-RING (26.4X3.1) (TEC)
      98079-5614N SPARK PLUG (PZFR6F-11) (PLATINUM) (NGK)
      12030-P13-000 GASKET SET, HEAD COVER
      38920-P0F-J01 BELT, COMPRESSOR (BANDO)
      90015-PT0-000 BOLT, TIMING BELT ADJUSTER SPRING
      90140-P14-A00 WASHER, PLAIN (11MM)
      90014-P14-A00 BOLT, TIMING BELT ADJUSTER BASE
      90016-PT0-000 BOLT, TIMING BELT ADJUSTER
      14510-PT0-004 ADJUSTER, TIMING BELT (NIPPON SEIKO)
      14516-PT2-000 SPRING, TIMING BELT ADJUSTER
      14521-P14-A00 PLATE, ADJUSTER
      91214-PH1-004 OIL SEAL (80X100X10) (ARAI)
      19222-P13-300 GASKET, WATER PUMP
      19223-P13-300 RUBBER, WATER PUMP SEAL
      91213-PR3-004 OIL SEAL (29X43X8) (ARAI)
      91212-P0A-004 OIL SEAL (40X52X7) (ARAI)
      91205-PL3-A01 OIL SEAL (35X56X8) (ARAI)
      91206-P0X-005 OIL SEAL (40X56X9)
      ...and thats because Im picky about everything, like my swaps to go smoothly, and not having to worry about shiet in the future. Im thinking of buying an OEM Oil Pump too...
      hope it helps, gives you an idea. if so, be ready to spend top dollar. Im getting alot more stuff other than this (ex: clutch, flywheel, kaizen, etc)
      '09 Mini Cooper S (R56)
        thanx alot good help oh i forgot to mention i was going to make it manual but i decided to keep it auto
          so price range wat am i looking at? any ideas
            well if you decide to go manual, you have the JY for options, or you could hit up www.explicitperformance.net.
              thanx again
                well, here's my parts list, again, so get a very close idea:
                Honda OEM parts: $450
                Exedy Stage 1: $274
                Fidanza Flywheel: $149
                H23 Dist.@ Advanced: $230
                Swap/Mechanic: $450-500
                KaizenSpeed Bal. Shaft Elim.: $135
                Walbro Fuel Pump: $100
                Gus' Food: $1 menu @ McD's (I heard)
                Beer: Priceless, I always have beer.
                Misc: $200(avg)
                and I might be missing something...
                  Exedy Stage 1: $274
                  Swap/Mechanic/Beer/Food: $450-500
                  Misc: $200(avg)
                  About the h23 distro. I hope you car is wired for external coil .
                  My System
                  http://www.cb7tuner.com/vbb/showthread.php?t=165155
                    1993 EX 5spd...external coil if not, Gus will take care of it.
                      haha nicce ok hmmmmm
                        Replacing the mounts is also a good idea. Thats if you have bad ones.
                        Hybridnation
                          i'd go to ebay from this guy. He's domestic gaskits and I use only his stuff cause it's affordable and GOOD quality and it comes with EVERYTHING you could need. pistons, WP, Timing belt, bearings, oil pump, gaskets... EVERYTHING. you'd have almost a new motor when your done
                          oh and one last thing if you don't have a f22a6 already in their you'll have to wire for your secondary butterfly's.. if you do than you'll just have to wire the knock sensor and vtec.
                          WTB:
                          88-01 prelude 2.0si (3g) si (4g,5g)
                          OR
                          90-93 Accord.
                          Has to be 5spd, has to be CHEAP. SUPER CHEAP. Will be in Indiana in February permanently and want a project car when I get settled in.
                            Cool, i did this swap last year and it's great I love it, tho i highly reccomend getting a tunable ecu and tune later on.
                            Mine was a 90 LX so i had to deal with the internal wiring. All was well until my distro took a shit on me. Then I got distro's from Autozone ( BAD IDEA), since I got 3 bad ones in a row. I finally just bought a JDm ditstro and have been frying rice ever since
                            Hope your freind knows what he was doing, my buddy claimed to and he ran tps wires to egr and egr to tps, that took 2 months of testing ecus and tracing wires and testing voltages to figure out what the hell took place.
                            Anyways, best of luck to you.
                            My System
                              Polyurethane Motor Mounts!!!!! I didn't do my swap but I have heard very good things about them!!!!
                              The CB7 Collector.
                              Team Kindred Impulse Member #3
                              92 LX Coupe F22A1
                              2013 Toyota Corolla S
                              92 EX Sedan F22A1
                              Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
