f22b water pump/ timing belt area.
    h23 or f22ax?
    i'm more concerned about the timing belt issue. has any one use the h23 pump? i know it's got the correct pulley (it matches the f22b). and will the h23 tensioner work for the f22b? i need a 100% sure answer.
    i know i should have done before i installed it in the wag, but i was too lazy and in a hurry. not having any problems just gonna replace it.
    yeah h23 tensioner works for the h23, because the f22a wont work because its not dohc. Also if you use the h23 water pump use the h23 belt and it will work fine beacuse the h23 pump has the extra tooth or two the f22a doesnt.
      thanks phatty!! i knew you'd have the right answer.
        Lol!~!~!~!~!
