Is a K24Z3 Swap possible on a Cb7? and which is Faster? H22a or K24Z3? Dumb question asking for dumb answer lol
The K24 swap is possible, and has been done by a couple of members. I'm not exactly sure which engine spec it was though.
Look up 2point6 and check out his member profile.
And as much as I love my H22, I believe that the K24 would blow it away.1992 H22A4 Coupe - R.I.P.
Bought from: slammed4thgen. new_beginnings. crzy.tuning. f20aaccordturbo. hondaguy1212. cb4_honda. fatboy1185. wed3k.
_____________H22A4CB7. minorreparations. PR CB7. plee3. Bisimoto Engineering.
Sold to: LadyG. sulimed. choppacity. choogee3.
Originally posted by SE_DynamiK View PostThe K24 swap is possible, and has been done by a couple of members. I'm not exactly sure which engine spec it was though.
Found in:
* 2009 Acura TSX
o Displacement: 2,354 cc (143.6 cu in)
o Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
o Compression: 11.0:1
o Power: 201 @ 7000 rpm
o Torque: 172 ft·lbf (MT), 170 ft·lbf (AT) @ 4300 rpm
o Redline: 7100 rpm
the best H22A is :
# Found in the Japanese 6th gen Accord/Torneo Euro-R (CL1). It produces 220 PS (162 kW; 217 hp) @ 7,200 rpm & 163 ft·lbf (221 N·m) @ 6,500 rpm and comes with a "red top"
If putting a TSX engine on a CB7 lighter weight then TSX it would be more then a H22
k24 is a better choice
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.
Originally posted by Brandoncb7 View PostThe K swap is so damn expensive though. You could drop an H in your car and take the money you have left over and build a beast.
But look at the torque from the H, 163 @ 6500;
compared to the K with 172 @ 4300.1992 H22A4 Coupe - R.I.P.
Originally posted by Brandoncb7 View PostThe K swap is so damn expensive though. You could drop an H in your car and take the money you have left over and build a beast.Bisimoto Engineering
1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
2) Email me, robert@bisimoto.com
3) Contact me on AIM, robert@bisimoto.com
Originally posted by robert@bisimoto View PostOr you can fully build your F22a1. The F22a1 has more potential than the any H-Series engine.There are no black and white suspension answers!!!!!!!!!!!
Originally posted by lazeepnoy View PostHow much will it cost for K24 Swap so I can start saving up?
I've seen some older model K24's from Accords that have gone for less than a grand.1992 H22A4 Coupe - R.I.P.
4 to 5 grand if you can get the hook up on parts, 5 grand plus if you pay retail for all parts.
kpro $1k
motor and tranny $1k-$2.5k
header $400- $800
mounts and axles $750
harness $350
clutch flywheel $300- $600
fuel pressure regulator $150
fuel rail $150+
fuel lines, fittings, hoses, etc... $100-$300
tune $300-$450MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
CHAMPCOUPE IS BACK !!!!
Originally posted by ChampCoupe View Post4 to 5 grand if you can get the hook up on parts, 5 grand plus if you pay retail for all parts.
kpro $1k
header $400- $800
harness $350
fuel rail $150+
tune $300-$450
wow 8000$ can you estimate on the h22a swap?
