need some help a few h22 ?s
    ok i am swaping in my h22 on sat and doing a auto to many. i am ussa a h22a with a 94 accord 5 speed tranny. my ?s are can i use my acccord drive shafs. or do i need the 94 accords drive shafs. what motor mounts do i need to use. i no i have to change the rear and tranny one but what ones do i use any thing eles i need to get.
    The Race Car
    Need This In Fo Pleas Help
    The Race Car
      i believe that you can use the accord axles should be the same.
        that what i thout but i relly need to no what mounts to use
        The Race Car
          Ok So I No I Need The Rear From A Lx What About Driver And Front
          The Race Car
            any one els
            The Race Car
              you need the ESP one for the tranny, or you can drill and tap holes. I just bought their mount kit for like 275 and get an LX/DX rear bracket and everythign lines up. I've got a JDM H22 M2A4 trans though, so be sure you get the right kit for the right trans.
              You'll also need an intermediate shaft and a 5spd axle for the drivers side. The pass side you can use the Automatic axle.
              member's ride thread
              91 Accord SE 176k
                ok thanks..
                The Race Car
                  option 2: custom transmission mount.
                  This is made from the stock AUTO transmission mount with an adapting plate that i use with my 5spd h22a trans
                    Or take a ton of washers and built a level to set your mount on while you go look for a better mount
                    Your man for wiring solutions!
                    CB7Man's Coupe H22 Swap
                    CB7Man's Sedan Resurrected From The Dead
