HELP! H22 obd2 to obd1 conversion
    please disregard the question the dizzy is worthless, it is not complete, if anyone has a obd1 dizzy for sale please pm me thanx...
    OKAY FELLAS HELP ME OUT WITH THIS...i have a h22a4 obviously obd2, im throwin it into my cb7...i dont want to buy a new dizzy for da h cuz theyre expensive so im trying to find out how i can make an obd2 dizzy work on an obd 1 harness, because i know it can be done from wat ive heard...
    luckily my old f22 harness has a 2 pin clip for the dizzy and the wires are blue/black and yellow, now my new obd2 h22 dizzy also has a 2 pin clip and same colors...heres a piccc...the harness clip is on the left....
    okay as you see the two clips go together perfectly so i dont have to splice anything rite?? tell me if im wrong...
    also the other dizzy clip on my harness has 7 wires, and the odb2 dizzy clip has 4, how can i splice them together if possible?? or maybe i just eliminate some of the obd1 harness clip???.....heres some pics...
    id appreciate all your help fellas thanx...
    Heart and Brain Transplant fail I had to pull the plug
    My new best FRIEND!!!
    any opinions anyone???
      you've got to wire up your crank sensor into the harness somehow. don't know how to do it.
      i did it the conventioanl way, swapped to OBD-1 distributor, injectors and ECU.
        OMG I just realized that the guts in the dizzy arent complete......f**k f**k f**k....i am heated this guy ripped me off, what a ***...
