well i found out recently that my H22 has some bottom end damage to pistons and cylinder possibly. so my plan is to do a F20b swap and possibly boost later on down the line,(Drummersteve's influence) and slowly build the H22 back for a all motor DA integra swap. i should be ordering my motor in about two weeks and swapping it before the end of july.
i have a P13 and a chipped P28 with a H22 base map can i use these ecu's or would something else work better? also i believe the F20b is OBD2 where can i find a OBD2 to OBD1 conversion harness?
