Calling all jdm DOHC VTEC h23a swappers
    I am thinking about doing a JDM DOHC VTEC h23a swap because of what I can afford and the h23a is in my area
    My car 90 accord ex f22a4
    Related h23a swap links
    http://www.cb7tuner.com/vbb/showthread.php?t=129574
    What are some of the issues I will run into because I looked through the h22a swap and I searched my butt off but couldn't find any ACTUAL H23A Swap guide..Please stay on topic so that who ever needs this info can easily follow the thread..I will update once your information is posted...ways we can make the thread swap clean (good example) thanks to these threads
    http://www.cb7tuner.com/vbb/showthre...ight=h22a+swap
    http://cb7tuner.com/vbb/showthread.php?t=81303
    Swap Guide
    Engine Harness:
    Engine Mounts:
    Transmission Mounts:
    Clutch/Flywheel:
    Axles:
    Air Conditioning(A/C):
    Alternator:
    Power Steering:
    Fuel Rail:
    Exhaust:
    Internal/External Coil Issues:
    For 92-93 accords, your harness is wired for an externally coiled distributor.
    space 1. Buy an H23 distributor(USDM h22/h23 are both external coiled, but the h22 costs more for some reason).
    space 2. You can buy an aftermarket coil such as an MSD Blaster coil
    Timing Belt/balancer belt/water pump/oil pump:
    Buy a water pump for an F22A. It bolts on perfectly.(thanks to dbsharp)
    Use an F22A oil pump.
    EGR:
    Water neck:
    ECU:
    IAB's:
    TPS:
    Spark Plugs/Plug Wires:
    Oil Pan Gasket:
    Other Gaskets:
    New paint job and bumper 8/8/11
    tsx retrofit
    f22b dohc boosted
    custom gauges pods
    Motivation is one of the keys to life....tell me "can't" and I wll show you I can
    as for the whole swap is pretty much the same as an h22 swap, the only thing is the drivers side motor mount is very different from the accord, u might get away with 94-97 accord or prelude motor mount
    also this engine is OBD2
    u'll need an internal coil DIS (ur car being 90)
    u can use ur alternator
    for ur A/C, u'll have to use f22 A/C bracket and compresor
    have to use ur flywheel+clutch (motor is AUTO)
    be on the look out for a OBD1 h22 plenum because the IACV on this motor has 3 wires (ob1 has 2)
    keep the TB, being one of the biggest TB honda made (65.86mm)
    if u want to hook up ur iabs thats all to u
    if u want to use the OBD2 inyectors, u'll have to cut and splice all the wires going to the resistor box
    or go the easiest option and buy obd1 h22 inyectors (290cc vs 345cc)
    use ur TPS, the one on the motors WILL be broken
    it uses H22 header, if u have an f22 EBAY full header, u'll need just the top part only
    as for ECU, if u dont have money for a chip and tune, use the JDM p13 ecu
    trust me, IT WILL RUN LIKE SHIT
    use accord fuel rail (h23a fuel rail has the banjo bolt on the other side)
    accord f22 EGR
    NO the F22 waterpump wont work, H22 will
    h22 timing belt, balancer belt
    h22 oil pump (why would u want to use f22?????)
    oilpan u can use h22, h23, f22, f23, f20b
    seals u'll have to use h22
    head gasket i reccomend h22a4 or a1, being that the h23a is open deck (obd2)
    thats all i can think of
    Just do what PR CB7 said.
      alright cool... thanks for putting your info
      tsx retrofit
      f22b dohc boosted
      custom gauges pods
        If you need help with the swap, shoot me a PM. I live on the islands
          RED??? = I was wondering if you were meaning the obd1 h22 injectors are 345cc and the obd2 that are on the block are 290cc????
          BLUE??? = And if I got ahold of oem h22 headers and downpipe it will work with swap??? or do I NEED to bet Aftermarket headers and downpipe?
            OH SHIT lol I see that he (^^^^^ PR CB7 ^^^^) is banned...damn
            lol
            can anyone else clarify
              P13 ECU is running my H23A vtec perfectly fine with great power and mileage.
              I used the internals from my F22A distributor and put them in the H23A vtec distributor. Took me 15 mins and works perfectly.
              The IACV was a big issue for me. You WILL need the upper half of the intake plenum off of a 93-95 prelude H23A non vtec or H22A. Try to get it with the IACV and all other bolt-ons. Keep the H23A Vtec throttle body though as it is bigger than the H22A and H23A throttle bodies.
              The 92-96 H23A non vtec or H22A vtec motor mount bracket (the one that bolts through the timing cover then your F22A motor mount bolts up to) Is also a MUST.
              your flywheel and clutch must be swapped as all of these H23A vtec motors are auto transmission stock. I did ACT 12lb flywheel and exedy stage one clutch and I have never enjoyed a motor more in my life. 2 very highly reccomended upgrades.
              If you are going to run a P13 or want more power just get a set of H22A OBD1 injectors. This makes things go alot quicker with less modification and you have the ability to tune for more fuel and power.
              I had to use an adjustable fuel pressure regulator but Im sure the H22A regulator would work if you can find one.
              as for the whole swap is pretty much the same as an h22 swap, the only thing is the drivers side motor mount is very different from the accord, u might get away with 94-97 accord or prelude motor mount WONT WORK
              if u want to use the OBD2 inyectors, u'll have to cut and splice all the wires going to the resistor box DONT USE THEM IF U CAN AVOID
              MY TPS WAS FINE DEPENDS ON WHERE U BUY THE MOTOR
              WRONG! RUNS GREAT FOR ME!
              use accord fuel rail (h23a fuel rail has the banjo bolt on the other side) WITH DIFFERENT FUEL PRESSURE REGULATOR TO ACHIEVE 41 PSI WITH NO VACCUM
              seals u'll have to use h22 I ordered all replacement seals and belts telling them they were from a 98 H22A
              head gasket i reccomend h22a4 or a1, being that the h23a is open deck (obd2) I thought all H22's were open deck??
              ^Click Me!^
                Read the stuff I quoted from our banned friend.
                Also yes the stock H23A vtec injectors are 290 cc high impedience and the H22A ones are 345cc Low impedience. If you dont want to have to cut out your resistor box and rewire every injector just run H22A ones.
                ^Click Me!^
                  OK...The only thing I am worried is if I use the h23a vtec injectors (the ones that are already one the motor) it wont be as powerfull as if I swapped them out for the h22a vtec..... or is that nothing to worry about?
                  Also, do you think I need to change the fuel rail with it aswell (if I swap the injectors to the h22a's)? or is it no diffrerence?
                    You will have to swap the rail due to the location of the FPR on the JDm ones being opposite the USDM ones.
                    "you can catch me swoopin 4G coupin switchin lanes" haha haha.
                    1993 SE coupe drag car ahoy!
                    1992 EX coupe 5 spd **sold **
                    Did work for: jhoff_cb7
                      Is there anywhere I can find an in depth guide for this swap with pics? I looked but found non.
                      I know where to get cheap H23 blue tops but I need more info on this swap if I ever want to make it happen. Being that it is an OBD II engine I am a bit concerned. Can I be certain that EVERYTHING said in this post is accurate?
                      Another question. What is the intake gasket on this engine is it the same as the H23 in America or is it like the H22?
                      And wait I can't use the H23's driver side mount bracket as it is but must have an H22 or H23 US bracket?
                      EDIT:
                      Thinking it over again I am not too thrilled about making this swap or any swap in general. The labor involved to do it again after I already rebuilt my F is not exciting. I think I am going to try real hard to fix the bad oil leak it has in it.
                      “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
                      ― Jeremy Clarkson
                        I never got to swap out the Driver side mount but I used a 94-95 VTEC Accord mount and fits bit will have a minor tilt due to the mount is higher position. The Motor soon will be re-swapped in my new chassis so stay tuned. The ECU i'm using is a P28 chipped with Chrome with H22A SIR Base Map(Red Top).
                        1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
                          So you used the stock mount bracket and just used a Vtec accord mount? Sounds risky. I heard you can use your F22a mount I want to be sure cause I'm considering this swap.
                          ― Jeremy Clarkson
                            crazy thread revival.
                            Anyways, can't remember exactly what mount combo I ended up with.
                            Gary A.K.A. Carter
                            [sig killed by photobucket]
                              bump because i need to know what timing side bracket to use. i ordered a h22a bracket from majestic honda and its the same fucking one thats on my jdm f22b dohc. neither bracket fits. what the fuck.
                              COUPE K24
