H23 Swap info request
    I've searched the site and all I can seem to find in the area of swaps is the H22, F22, and Hybrids/Frankensteins of some sort. Is there something wrong with the H23 as an inexpensive upgrade if your motor goes out? What all is needed to make the swap work? Is this too hard, not worth it, or just so common I should be smacking myself in the Nads for not knowing this already? Thanks for the help guys and gal(s)!!!
    edit:<<<<<69th post!! W00t!!....sorry. I can be immature at times...
    ~Built not Bought~
    --member ride page--
    http://www.cb7tuner.com/vbb/showthread.php?t=130234
    pretty much the same as JDM F22B DOHC swap.
    1990 Frost White EX Coupe F23A1 - PART OUT
    01 DC4
      what is pretty much the same? the power made? the cost? materials needed? the reason I asked the question was b/c there isn't a very clear answer....
      ~Built not Bought~
        [link]http://cb7tuner.com/vbb/showthread.php?t=81303[/link]
        That should help. I followed that guide when I did my swap. But honestly if you don't plan on going turbo, don't do it. Hope this helps you.
        Originally posted by nine_deuce
        What I'd do is this: spray brake fluid in her eyes, shoot her with a nail gun, while she's down, give her a "chili dog" or a "strawberry shortcake" a "rusty fish hook is always fun"
        91 ex auto-sold!
        92 lx wagon-sold!
        92 ex parts car-sold!
        I NEED ANOTHER CB PM ME IF YOU HAVE ONE LOCAL!!!!!!!!
          You don't think it's worth it w/o turbo? Even if it's just for an inexpensive hp increase if my motor goes? I'd think it would be better than the stock F?
          ~Built not Bought~
            I just swapped in an h23 and I like it. The torque curve is great and really makes it a fun motor. I would say that unless you can pick one up for say $200-300 then you might as well just get another f for cheap. The h does drink a little more gas, but as always it's a honda motor so it still gets decent milage. It's all up to you man.
            To see my car click here
            Bordeaux Red Crew #8
              just follow the F22B DOHC swap guide...the only difference I can think of is the USDM H23 will have a external coil distributor.
              01 DC4
                knock sensor.......unless you use a p39 or a chipped ECU
                  Why is this??? Please explain why not??
                  I swapped in an H23. Its a fun engine.
                  I ♥/Miss My Coupe
                    I was thinking it would be better than stock and almost as cheap. Doesn't it make about 160hp? And wouldn't I be able to use the ecu out of the 'Lude?
                    ~Built not Bought~
                      you can but you'd have to wire up the knock sensor. not hard to do, it's just
                        x2
                        It's not worth tuning though unless you have a hook up like joser over in cali or unless your doing some work (turbo!) to the motor .
                          I'm not in Cali. I haven't even been there. lol
                            right. Yeasman was in cali. Got it all mixed up from the cam swap fiasco. haha sorry.
                              SO this is a viable option, but not a lot of people do it? Is that why I didn't see direct write-up on it?
                              ~Built not Bought~
