h22 swap help
    h22 swap help
    I am swapping in a obdII h22 into my 91 wagon. With the motor being external coil and the car being internal, how do I get that? My shop wires up the external coil with the "3 wire" setup but still no spark. We are using the f22 wire harness , if that matters. Please help.
    it can be done, i cant tell you how, but the guy that did my swap did it, he had been working on cars for a while, but it can be done, just search the net or even here, but i know how it is when you just want to get it done, you barely have time to search
      I got a book on the swap it tells u everything from odb1 2 odb2 swap exrnl 2 entrnl coil swap and every other problem u might run in 2. give a sec ill find it n tell where 2 get it.
        www.ultimateresourceguides.com check it out, if they still have the same "ultimate h22a swap guide" its streight foward and direct, cant screw it up.
