When my H22 is cold it idles like poop/// P-13 ecu but when it is running for 20 sec or more it starts to get higher in idle and stops studdering......any thoughts
Cold Idle Problem.....
Originally posted by veyvey View PostWhen my H22 is cold it idles like poop/// P-13 ecu but when it is running for 20 sec or more it starts to get higher in idle and stops studdering......any thoughtsMy cb7
h22a
5-spd lsd
Lord, grant me the serenity
to accept the things I cannot change,
the courage to change the things I can,
and the wisdom to hide the bodies
of those people I had to kill because they pissed me off.
yeah i will clean mine today and see
I changed my Idle Air Control Valve (IACV) from my f22 to my h22 and its not helping I cleaned my IACV from my f22 before installing it to the h22. (its just the idle is rough when it first starts and then it becomes stable if it stays running) so could this be the Fast Idle Control Valve (FICV)? Or maybe the Dizzy?Last edited by veyvey; 03-10-2009, 01:19 PM.
also could be the gaskets around those valves if they're old. they tend to get dry and brittle over time and will therefore not seal anymore. So check for any vac. leaks. I just bought a set of new o rings for both valves, and it totalled about 11 dollars for me from honda, so I hope that fixes my quirky idle issues.
