hey wats good cb world... i just got a f22b1 sohc vtec, i dont remember the miles but the car had syn oil and i called the dealer and asked him if its ok to change it to reg oil he said sure.....so i switched it and now its giving a knocking noise now ...wat can i do to get all the syn oil out , can i clean the oil pump out and strainer out? because the head has sludge
engine knocking
If you can tell the noise is in the block and you do the main bearings, make sure you do the rod bearings too. How many miles are on the engine?
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
See if you can tell over which cylinder the noise is coming from so you know where to look. Take the valve cover off, and inspect the valvetrain for problems when the valve adjustment gets done. I have a high mileage F22B1 head that could be used for parts if something is broken, but a valve adjustment sounds promising. A feeler gauge costs about five bucks if you don't have one, and you don't have to do anything but take the valve cover off and turn the motor to the right spot for each cylinder to check the gaps.
Better to have noise in the head than the block, I say. As long as someone didn't mess up the timing and bend valves.
the only thing was changed was the timing belt and seals and the dummy advance the timing 7 degreesLast edited by hondaguy305; 02-15-2009, 12:59 PM.You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
