Header question.
    Header question.
    This might be a newbie questions but will my f22 down pipe fit on the f23???
    My Memebers ride thread is comin soon keep out on the look out.
    on an f23 header???
      which F22 DP? there's like 3 versions: A1, A4 and A6.
      A1 is 4-1.
      The A4 is a tubular 4-2-1.
      The A6 is a Cast iron 4-2-1.
      A4 is the best out of those 3 for the most hp.
        i have an f22a4 but my f23 came with a header just not the down pipe will my f22a4 down pipe work??
          I don't think anyone on here knows unless they've personally worked with an f23 before.
          The only way you're gonna get a solid answer is to find out for yourself.
            yeah i figured oh well we will see
              Originally posted by Losiracer2 View Post
              which F22
              That doesn't matter as each of those have the same bolt pattern etc...f23 just has a different bore, but is also on a newer engine...so until someone actually trys it out we won't know...
              ____
                im working on this same question with the same swap right now... that is just about the only thing i have left to figure out and the motor is in and running. anyways i am going to buy a header for a 94-97 vtec and i had a header on my f22 and i am hoping that the f dp will bolt to the upper part of the other. if it doesnt then i will just have to make the new header work i guess
                my ride
