I found the wire harness for my jdm f20a dohc and there's a thick white wire that is cut. What wire could this be? Power for battery or maybe a ground? I'm not sure what to do with the f20a either keep it sittin on the side of the house and leave the f22a6 in the cb7 or do a motor swap.
f20a dohc wire harness
nothing, the stock one plugs right into everything. the f20a should have no sensor on water neck on the front of the head, just swap that over. everything else is normal. just unplug the stock harness, put it on the f20a before dropping it in. remember the f20a is from a CB so all is the same.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
if it is a larger 8 gauge wire it probably is for the alternator, either on the fuse box side or alternator side
http://www.tasauto.com - The Accord Experts
I know the motor is in my garage now and all, but to go from an ext. coil to the int. coil you just have to put a fuse in of of the plugs as a jumper to give it power.. at least thats all we had to do when i did the F22b Dohc swap...I like having the Int. coil so ill work out how to hook it up.. . .93 Ex F2.0A Si. . .
WiredMotorSports
