h22a auto / TCU QUESTION??
    i have a h22a with a jdm p13 and the stock f22 auto TCU .. i kno the p19 is the auto TCU for the h22a . also i cant find one anywhere ... i can get a P5M out of a 97 prelude which also runs the h22a auto but it has tiptronic can i still run this TCU or not??
    no ... it won't do you no good... just get the p19 or p0n. i can get you one if you got money on hand because usually when i get them they go fast. you will probably need 150 bucks.
    Originally posted by Devergote
    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
      thanx meng i need one ... if can get a hold of one let me kno . my names eddy you and joser fixed my white coupe ... there were like 3 p19 on ebay pero didnt have da money ... but jus let me kno meng ...
        if tn accords cant find you a p19 i have one on hand. ill willing to part from it lol
        no
        Accord turbo kit under $2k here
        $30 HID kits here Thread
        "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
        "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
          sweet ... ima pm you ..
            lol... i was going to ask you if you still had yours man ... good luck LAW. !!
              oh for real lol?
              no
                yeah you can get a P0N, P19 or the P0F....which is what I have. It raised my shift point to 7000 rpm.
                What I need to find now is another P13 Automatic....I think mine may be giving me issues
                  you can still use a p13 manual ecu you know
                  no
                    i didnt kno that u can use a p13 manual ecu....
                      then my D4 light will flash, I tried that w/ my friend's P13 ECU he got w/ his H22 swap for his accord. So the TCU may not work properly if you use a 5spd ECU.
                        mine didnt flash when i used it. guess its only on some motors/tranny combinations
                        no
                          Definately need that computer with that trans. I tried an H22a with my F22a one and it didnt work out too well. I would bounce off the rev limiter until it decided to want to shift. I would assume if you put in the F22a tcu with an H22a trans I would shift at like 6k.
                            Ok I'm lost. I want to do an auto h22 swap. I got the p13 ecu. Now do I need a tcu or will I be ok?? Because I didn't see anything about a tcu in the diy hss sticky
                            我愛我的本田
                              no it'll work w/ the F22 TCU, but only shift at 6K and you won't get nearly the advantage of the H22 as you'd hope.
                              But then again, you could always manually shift through the gears and still go to redline....but to me that's stupid since you have an Automatic, it should do that for you.
