hey people well as you can read i am doing a g23 swap cause i decided to keep my f22a1 block so the problem is that i need help and advice with this swap.. im tired of hearin people telling me to do a h22 swap i dont want to do it cause everyone else already has those swaps i want something different also i am doing my build ALL MOTOR so i was wonderin what good of high compression pistons would be good to drop in my block?? and what type of cam shaft should i get?? i heard i could use skunk2 cam shaft what do you guys think about that?? also should i go vtec o no?? since my car doesnt comes vtec(but it was throwing me a cel code 21 which is vtec solenoid) but i cant find it help plz... should i get a h22 head or a h23 head?? im not so sure which one is the one that bolts right on to my block.. please help me out guys im trying to get this car done b4 the summer comes TIA
ill try to keep everybody updated with the swap ill post some pictures up
before i started to take it apart
after i took off the battery and the p/s resevoir and the p/s motor
after takin off the valve cover,valve n springs,cam shaft and alternator
after takin off the IM
after takin off the head
after takin off the bumper,bumper support,and headlights
after takin off both fenders,hood, and started doing the wire tuck
and this is how she sits now
hopefully soon i should be goin to the junkyard to go pick up another set of wiring harness and to go get the clutch,brake, and accelerator assembly and all the lines i need to do the auto to 5spd swap... i already tooked off the auto shift cable and the auto gear shifter too tomorrow ill work on gettin the tcu out, all this i have done it in 3 weeks.. its hard for me to work on the car cause i dont have a garage
