when doin a h22 swap do you use stock axles and half shaft and shift cables and motor mounts or use the preludes?
swap question
Originally posted by Flatline View PostNope all stock. the only thing you need to do to mount it is if you use the lude tranny you need to widen a bolt hole.
Look it up in the swaps section. also if you search you'll find tons of threads about it and things to look out for51% motherfucker 49% son of a bitch
