any f22a1 belts fit h23 non-vtec?
    okay, swap is going in this week and i got some new f22a1 belts and i was just wondering if any of those belts will fit onto the h23 so i wouldn't have to buy ALL of them...maybe just some, if the f22a1 belts can be swapped.
    help?
    thanks,
    Los
    VQ35 POWAH!
    If you mean timing and balance belts, no
    PS belt yes
      PS belt yes
      okay, so i can use my new PS belt...i'll just have to buy the h23 timing & balancing belts.
      thanks brohymn!
      VQ35 POWAH!
        yeah the PS belt and the other belt that goes around the crank pulley, i think its like the serpentine or whatever, around the AC and alt...
          p/s belt yes alt and c/c belt yes. balance shaft belts yes timing no.
            thanks guys...that all helps tremdously...but i just happened to look at the bottom of my block (inside the oil pan) and found that i need the bottom main bearing caps and the bridge that covers the crank...so until i find this item, the swap is on hold
            VQ35 POWAH!
