F22B Timing Belt
    F22B Timing Belt
    Can someone tell me what timing belt to use on the JDM F22B DOHC engine? And before you say search; I've been searching and test fitting belts for days now.
    Heres the F22B Timing Belt #'s
    126 teeth-length?-24mm Width
    The only suggestions that I got where:
    94-99? Integra GSR- most people with the f22b swap use this one; but I got one,
    126 teeth-same length as f22b belt-width 26mm
    and it rubbs against the balance shaft pulley...
    92-96 Prelude Si- one or two more teeth, which also says its longer lengthwise, but it has the same width-24mm
    I have been to Honda, Acura, all the local part stores, and have yet to find ANY belt that will work.
    Help please.
    Jay
    Hittin Switches - Draggin XhaustAlways Under Construction
    it doesnt rub. i just did this last week on huy009's swap.
    welcome to the DOHC-side..muuuahahahahahah
    http://www.cb7tuner.com/vbb/showthread.php?t=1906
      Every one else used the grs/type R belt, but i used the h23 one, and it works fine
        f22-dohc: Yea, it does...I checked it over and over again...it rubbs the pulley that balance belt and timing belt are both on. I should have snapped a pic while it was on...but I've already returned it.
        phatdoughnut: The h23 belt has at least 1 more tooth, maybe 2, and its not too loose? Might have to retry that one...
        Anyone else?
        Jay
          Anyone else?
          Jay
          i dont know man, thats a weird one... oem honda/acura parts ur using???
          everything cleared w/o probs when we did this last week.
            First I tried an AutoZone GSR belt, then went to Acura and the same problem...
            But I think I MIGHT have found a source that will be able to hook me up with the Unitta belts...
            Jay
              screw it, take the balancer belt off.
                Thought about it...but theres gotta be a good reason why Honda put it there in the first place.
                Also FYI, I think I might be able to get the CORRECT belt imported here through a friends buddy...if I goes through I'll let all the F22B, F20A, F20B etc. people know.
                Jay
                  What belt did you use?
                  Sold, but not forgotten.
                    gsr
                    mine is also gsr
                      ..same here; used the H23 belt and no problems
                      5.6L V8 32V DOHC
                      JDM HERITAGE - US BUILT
                        exactly, i think you guys arent tightening The belt up enough, my h23 belt is Tight
                          Maybe...but you can only tighten it so much.
                          F22B: 472mm versus H23A: 476mm, thats a good bit of slack your going to have to take out...
                          Im still going for the correct belt, Unitta F22B/F20A belt; 472mm length, 126 teeth, 24mm width
                          Jay
                            92accordDx had the same problem, he told me he went to autozone and got a belt after the one he ordered didnt fit try getting in touch with him maybe that way you dont have to wait for shipping or anything
                            My Cb bad, Cb bright and the cops can kiss my Cb lights - I’m gone!
                            Frost White Member 13
                            My Ride
                            "Girls are like a new car... lease w/ option to buy"
                              Yeah
                              Hey guys, any help will be nice to know what belt to use, im tearing my F22b apart this winter and i need to find out what timing belt and water pumpto use. thanks
