5spd conversion...PEDALS wiring
    im in the proccess of doing the 5spd conversion on my 91 LX. I was gonna replace the whole brake/gas assembly however it is much easies to just replace the brake arm for a manual, so thats what i did, now i need help making the reverse lights turn on when i shift into reverse. any help will be apreciated....
    [SIZE=4] IMPACT
    [IMG]http://www.imagestation.com/picture]
    as for the pedal, your right, & thats how I did it.
    as for the reverse lights I think theres a diagram for it...
    here read this...
    http://www.cb7tuner.com/vbb/showthre...085#post703946
    93 Accord LX Sedan (sold)
      if it's easier to just replace the brake pedal itself with one from a manual i'll just do that because it was a pita trying to figure out how to remove the assembly from the donor car.
        here read this...
        But how do you manish to place the clutch pedal because the brake and the clutch pedal are on the same bracket. But I know, it's a real pain in the ass to replace the whole assembly
        Your car is faster, I'm the better driver
        Greetz Erwin
        My last ride
        Shakes and Fidget - The Game
          maybe on RHDs. but not on LHDs. on LHDs the gas & the brake share the same bracket
            open ur eyes the holes for the clutch pedal are already in ur firewall its a simple bolt on the hole for ur clutch master cilynder is there 2. @ the factory they didint have time 2 make a bodie esoecially for auto ot manny so all the factory holes u need 2 convert are there for u just a matter of taking ur time.it is easyer 2 just replace the brake pedal its a lil more work getting the brake and gad pedals together but since the gas pedal on manny and auto are the same keep ur gas pedal althogh i swapped the the whole bracket and it wasint that bad at all.
              You're right
              I thought it the other way round. True, the gas and the brake are on the same bracket. But still it's a pain in the ass.
              Greetz Erwin
              My last ride
                yeah when i pulled mine from the Junkyard i just pulled the petal itself. the spring that holds it in place is a bitch tho. the clutch is easy once u figure it out. daym cotter pins. gl with the swap man.
                [COLOR="Magenta"]
