Hey, anyone know what the round sensor directly under the intake manifold on the block is for on a H23a1? It has a 2 pin connection, its kind of like and above the oil sensor. I when to plug it in today and the electrical portion just fell off and I need to know the name for locate a replacement. Thanks.
rear engine H23 sensor unknown
^^^ I think hes correct
93 Accord LX Sedan (sold)
^^^ I dont think the accords F22 had one. so if it ran without one the H23 should be able to run without it too as long as you use a CB ECU. if you use the H23 ECU then I dont think it will & if it does I think itll throw out a code.
^^^ itll still run. & youll be able to drive it. it just wont be perfect
Plenty of H23 blocks laying around in junkyards. If not search on prelude power I am pretty sure someone is willing to sell you one with their partouts for cheap.
Originally posted by chrischhornhonestly it would be worth it to just find the a plug and run the h23 ecu and run the wires to the ecu.....Would good is doin a swap if u dont get the full potential out of it anywayz
yep that would be the best way!
thanks guys, its actually for my prelude. Now I know what I'm looking for. Theres no h23 around here, I had to drive 2 hrs cross state for this replacement block alone.89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
94 Honda Accord 2.2 EX (Daily For Now)
04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
