H23, using LS integra ecu?
    Would this work and/or work better then the F22a1 ecu if I couldn't find a P14 when I do the swap? My car is a '90 so is it obd1 or obd0?
    Honda-mans best friend!
    who said it was a dog?
    PINOY PRIDE
    OHIO CB7's
    obd1 iam using a p13 for a h22..
    Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
    But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
      you could get a better a6 ecu cam shaft and intake mani
        I dont reccomend using an integra ecu to run the H23. not even the F22A1 ECU. the best you can get away with is an A6 ECU, and even then youll get a knock sensor code. all cb7s are OBD 1.
        Originally posted by kc8enb07
        does it come w/ jdm trash? they better throw away gold in it
          ok thanks
          PINOY PRIDE
          OHIO CB7's
            Find a p14. You can find a shit ton in junkyards. You might be able to get away running a pt6 (I know a few people that have done this on F22B) but yea. You will most likely throw a CEL for KS I would think if you did that and it would make the car run like complete shit. Anyway just source a p14 from the yard. I would check preludepower.com they always have partouts of h23 powered preludes so not hard to find.
              You would not get a KS CEL with a PT6 because the F22A6 does not have a KS.
              Gary A.K.A. Carter
              [sig killed by photobucket]
                True. I fail.
                  True. I fail.
                  Nail = fail.
                  Coincidence? I think not.
                  Gary A.K.A. Carter
                    ^^^ so when swapping in an H. if you use the CB ECU you can go with out having the KS connected?
                    93 Accord LX Sedan (sold)
                      Yeah, but you would not want to do that. It will run like shit.
                      Gary A.K.A. Carter
                        I have a USDM Manual P14 for sale if needed.
                        -1991 Honda Accord LX H22a-
                          what's the price?
                          PINOY PRIDE
                          OHIO CB7's
                            pm'ed
