does anyone know what rotor to use for the f22b dohc motor its internal and it has a rotor that is held on by a scew. i bought one for a 91accord that has an internal dizzy but it doesnt have a screw to hold it on can any one help me out ?
f22b rotor?
I used a 92-95 Civic Si internal coil cap and rotor on my F20A...
although I have heard that 99-01 B16 Civic Si caps and rotors work well...but I have no firsthand on that though...
it kind of depends actually... did you keep the internal coil? or switch to external? if you switched to external or used an ext coil dizzy then I'd just use the H23A1 rotor...although I guess there's no real reason why you couldn't just use the H23A1 rotor regardless of the coil...
I got my Civic Si rotor for free with the cap so I used that...
gawd the original rotor was hard to get off though...evil little screw...I can still almost smell the liquid wrench and PB Blaster...that and a very long phillips that matches the screw exactly helps immensely...
that tiny little screw ranks right up there with axle nuts and crank pulley bolts...bleh...
i used the accord one...H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Sorry to revive this old thread, but Ive been searching and havent really found my answer...
Question: My 92 lx is external coil, my f22b is internal...and through shipping somehow the cap got broken, so I know I can either use 90-91 or 92-95 si cap, but my question is when I keep the engine with the internal coil, will I have to modify the wiring, or no? Because in other threads it kinda lead me to beleive that if I keep it internal, I would have to mod. the wiring for it...???
JayHittin Switches - Draggin XhaustAlways Under Construction
Yeah, you are gona have to wire it up! its easy!
unless you go out and buy an external h22-23 dizzyH22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Internal/External Coil Issues:
If your car came equipped with an internal coil then the JDM H22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wires together. The Black/White wire is useless, don’t worry about it.
