**F20B/easy uprgrades?**
    i'll be getting my motor in about 2 weeks..i don't plan on installing it till mid sept. but would like to upgrade certain parts if possible. i know this motor is similar to the H22, therefore,
    -can i use Skunk valvetrain, cams
    -convert to external dizzy that i have from my f22b
    -convert to the manual tensioner from my f22b
    -headers for the H22
    -what timing belt..just want to make sure
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
    dont quote me but i believe its just like the h22a besides being 2.0L h22a skunk 2 cams can be used as the valvetrain is still setup the same.. this is my assumption.. same thing for cam gears..
    the size of the crank pulley im not sure it is an F so it may have the Fs larger pulley or the H22as smaller one.. that is one thing to be found out..
    like i told you
    do bolt ons and a lightweight flywheel.. anything from there on is gonna cost you tires
    intake-same as h22a's
    header-same as h22a.. ur goal is in being different right?? how many ppl do you see with the prospeed/elite header or SMSP or AN-R ... those headers are TRUE race oriented...
    exhaust.. id still sport ur apexi WS
    fidanza or w.e make u feel comfy with 8-10lb flywheel
    clutch upgrade
    as for the dizzy.. you can convert any dizzy setup.. just some wiring involved.. it is OBDII so it may take more effort than just doing OBDI internal dizzy to OBDI external.. so that we shall see..
    about the tensioner.. the f22b/h23a share the same tensioner right? then it still applies.. and yes you can still use it.. like i said though this is all my assumptions on this motor... which not to many have ventured into.. i.e making this.. "different"
    Praise The Lowered...
      I believe you can use the f22b intake manifold, because it has p13 stamped on it.
        last time i saw one of these it had a diff IM on it.. it was the auto vesion.
        welcome to the DOHC-side..muuuahahahahahah
        http://www.cb7tuner.com/vbb/showthread.php?t=1906
          ..can't do that, coz i sold the f22b IM a couple months back.
          ..how can u tell from the IM its the auto version?
          5.6L V8 32V DOHC
            I doubt autos have a different intake manifold. It wasnt a smart move by honda if it does..
              thats what i thought..read up on one of the forums saying that the autos had a smaller tb, and different cams...i guess i'll find out when i get the motor in about 10-12 days.
              5.6L V8 32V DOHC
                i dint have to!!!! tranny had a yellow dipstick!!!!!! and right beside it was an h22.. so i was comparing...
                  I thought you said the upperplenum was stamped P13 and the lower was the H23A1/P14...???
                  I would personally keep the F20B manual cams... they are pretty damn close to TypeS cams... dunno about the auto cams though...
                  the ports on the F20B head are beautiful though...
                  RIP Lifsatrip7
                    wish I had the money for the F20B swap... just cause you dont see that everyday!
                    OS^e
                    1993 Honda Accord LX Coupe
                    My Members Ride's Thread
                    StickyDilJoe: "JDM may be a fad, but making your car look like shit... thats forever"
                      the f20b head ant type s head are the same. same cams, vaives, springs .a siIght p0rt as c0mpared thr the n0n type s heads.
                      s0rry ab0ut the "0's" and "i's" keyb0ard driver sucking
                      Life is wide, limitless. There is no border, no frontier ~ Bruce
                      My Page!
                        no they arent, they are like 2,500 dollars. but i bet primo got a super better deal then that... did you get it from that kid that wrecked his accord?
                          but i bet primo got a super better deal then that... did you get it from that kid that wrecked his accord? [/B]
                          ..damn, sorry to hear about that kid but naw, didn't get the motor from him(don't know anything about that). as a matter of fact, WikkeDV16 put me onto the motor, no tranny, but a fidanza flywheel, and an UR crank pulley should help me out on the revs..
                          5.6L V8 32V DOHC
                            any H22 LSD tranny should be almost comparable to the F20B tranny...
                            gear ratios...
                            M2B4 H22A LSD tranny
                            1: 3.307
                            2: 1.950
                            3: 1.360
                            4: 1.034
                            5: 0.787
                            Final Drive 4.266
                            T2T4 F20B LSD tranny
                            1: 3.285
                            2: 1.956
                            3: 1.344
                            4: 1.034
                            5: 0.787
                            Final Drive 4.266
                            BTW what tranny are you going to use with it?
                            RIP Lifsatrip7
                              ..was gonna use the A6 tranny; but by the time i get this swap done, i should have a H22 tranny by then
                              5.6L V8 32V DOHC
