Back to the good ol' rotating mass question
I know that the larger the wheel, the heavier it is. However, it's obvious that the larger the wheel, the less heavy tire you'd need. I'm just wondering if anyone has an idea on the optimal configuration for weight.
I'm thinking 16" wheels with standard tires (nothing over- or under-sized) would be a good middle of the road...
I know wheel and tire width (adding to the weight) is also a factor in going fast (more area = more traction, hopefully), so that would definitely be a confound...
Any ideas?
Any ideas?
