What size tires are you running (15's)
    I've searched and I've only seen a few posts about what size tires people would reccommend. Two posts have said 205 55 15 would be ideal but I've also seen people saying 205 50's so whats the deal. Im comparing dont want to throw my shit out of wack but I also dont want the huge sidewalled tire thats on the car now.
    iam running 205's 60 r15.....
      the stock size is 195/60/15. later.
      Avoiding dirt at all costs
        Stock is indeed 195 60 15
        My Azenis are 205 50 15
        members/ride | the/website
        180 hp/145 ft-lb
          205/50/15 works well for me, but looks low profile if your not lowered
          jdmCITY.com
            www.aznkid.com
              Using tire calculators, i never understood how a fatter tire would allow a smaller sidewall and still maintain the correct size diameter, for example using this miata tire calculator...http://www.miata.net/garage/tirecalc.html
                I have used this calculator in the past http://www.1010tires.com/TireSizeCalculator.asp
                Lets you change your rim sizes and is more vehicle specific then the Miatia one. Later
                  Dear Conspiracy,
                  SEARCH LIKE A NOOB!
                  http://www.eunos.com/tirecalc/tirecalcold.html(I use this one)
                  http://www.dakota-truck.net/TIRECALC/tirecalc.html
                  Enter stock size of XXX/XX/XX
                  Then enter what size tire you are looking for. Its that easy, its that cheesy. If you had done a little reaseaching, you would see that people like the 205/50 because of the shorter sidewall. But, I'm guessing you dont have any real idea why that is a good thing, do you?
                  I hope those links I sent up helped you. Even though you did not include what you wanted the tires for (Autox? Drag? Road Racing? DD?) I assumed that you were talking about DD since you didnt want your car out of "Wack (yo)".
                  205/50/15 - 4.7% fast @ 60mph.
                  205/55/15 - 1.4% fast @ 60mph.
                  205/50/16 - .6% fast @ 60mph.
                  205/45/17 - .2% slow @ 60mph.
                  So you can clearly see why 17's are such a popular choice - you get the low sidewall (45 isnt supper low, but its pretty low) but you dont sacrafice your speedometer accuracy.
                  The down side to 17's? Tires can be more expensive if you dont shop around (and you dont even like researching, shopping is probably outta your league), 'lowpros' can make the ride more sensitive (see: bumpy, harsh) than stock sizes. 17's also are usually heavy unless you get a good deal, or buy Kosi Rims (the sex for the price). Also, there is such a thing called rotation mass...
                  Verdict? Lots of people go with 15 rims with low pros. Even though its silly looking on 15s, it still helps the can handle better, but it does throw off the speedometer.
                  More questions? Comments? Send em my way! I love talking about rims and tires (even though I dont really know much about either in all honesty compared to some folks).
                  PS Sorry if I hurt your feelings, hopefully you got the point that all of this information has been covered many many times over, and can be found by simply spendling literally a few moments reseach.
                  Dont be lazy; do it.
                  - Zipcreature
                  Awesome!
                  CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                      Originally posted by accordoholic
                      205/40/17
                      Definitely not the right size for our cars. The sidewall's too small. It's got a smaller diameter than stock which increases wheel gap. It's an okay size for a Civic/Teg, so that's why they're always added in the packages.
                      With that small a sidewall, the ride will suck as well. I'd run either a 215/40 or a 215/45 depending on the drop.
                        on my 17s i had 205/40/17s and loved the look just because i have such an extremem drop but ur 100% correct on the above if ur not completely slammed... and yeah i could feel the paint on the road when i went over it
                        as for 15s i have had 195/60s and i dont like the look as much as 205/55 and my next tires will be 205/50s
                        "Tucking tires and wires."
                        The Chronicles.
