I need some help with some wheel fitment
    i know alot of people on the site ask if these xxr 0 offest fit... you guys know the rest but these are about some bbs rs replicas they are 17x7.5 with 35 offset. my cb is lowered 2in all around. my question is am i going to have any rubing or any other problems. i dont have rolled fenders and i dont have camber kit. i love these wheels i just dont want to spend the money on these and they dont work out for me. any advice will help my opinion is they should be fine with no rubing but im i figuie id ask someone with more experience thank you.
    http://www.ebay.com/itm/BBS-RS-Style...49699c&vxp=mtr
    http://www.cb7tuner.com/vbb/showthread.php?t=194049
    What tire do you plan to run? They should fit, but check this out:
    http://www.willtheyfit.com/index.php...&Submit=Submit
      Originally posted by wildbill83 View Post
      what Tire Do You Plan To Run? They Should Fit, But Check This Out:
      http://www.willtheyfit.com/index.php...&submit=submit
      215/45/17
        That is what I assumed, if you click on that link it will show you stock VS your proposed wheels. Ignore the suspension on the illustration.
        They will poke about 1.3937" or 35.4mm more than factory, but with no camber kits it should clear the fender, but you may still have to roll the inside, but possibly not.
          ok thanks man for all the help
            The sarcastic half:
            After experiencing a few years of people asking if rims "X" will fit, I have decided one thing:
            If you are even asking, then that means you have probably already decided you are going to buy them...and if they are an offset that is even slightly questionable, and you are committed to buying them, then you are going to do whatever you can to make them "fit". So why ask?
            So yes, they will "fit".
            The serious half:
            7.5 wide +35mm offset is not that crazy. I don't like hellaflush, nor do i know much about it, but considering I was going to put 8" wide on my coupe for purely race....it shouldn't be a problem.
