ok so i have a set of rims which are 2 piece. my question is if there is a company that makes just the outside of the wheel were the tire is mounted so i can use the center part from my current set up? i want to go -offset
custom 2 piece wheels??
if theyre real 2 piece wheels there is only 2 parts to the wheels:
face
barrel
i would make sure if theyre 2 piece first, and find out the manufacturer of the wheels. most parts are interchangeable because of the amount of bolts holding the face down.
only way to find out if theyre 2 piece is removing the tires, and checking the seam, some 3 pieces are welded at the lip and inner barrel.
3 piece wheels are:
face
inner barrel
outer lip
