Whats up guys. Stumbled upon some jdm 96 ITR wheels. I know the bolt pattern is right for our cars, but I read somewhere while doing a search that I will need to shave the caliper or put spacers on it. Is this true, or are they direct bolt on with no modification needed? I have a 90 EX with rear drums if that makes a difference. Thanks!
96 Integra type r wheels... Direct bolt on?
Originally posted by Theos92VR4 View PostWhats up guys. Stumbled upon some jdm 96 ITR wheels. I know the bolt pattern is right for our cars, but I read somewhere while doing a search that I will need to shave the caliper or put spacers on it. Is this true, or are they direct bolt on with no modification needed? I have a 90 EX with rear drums if that makes a difference. Thanks!
The best solution is to buy extended studs and then you can run whatever spacer you want to get a wider track, like 20mm.There are no black and white suspension answers!!!!!!!!!!!
Originally posted by mndude07 View PostYes they will fit but you need to do one of the two things like you said. The problem is, shaving the caliper isn't safe, and adding the 5mm spacer required to stock studs doesn't give lug nuts enough thread to hold on to, and can cause them to gradually loosen. I've seen it happen personally with 96 itr's on a cb7.
