I'm looking at a set of wheels and the rears are 16x8 and the offset is in the high +40's...I'm worried I might get interference with the rear knuckle arms or rear trailing arms. Does anyone know if they will fit?
Offset help on 8" wide wheels.
Originally posted by vinbon63 View PostI'm looking at a set of wheels and the rears are 16x8 and the offset is in the high +40's...I'm worried I might get interference with the rear knuckle arms or rear trailing arms. Does anyone know if they will fit?
He's talking about interference with rear trailing arms/knuckles bro...Running +15 offset, you will NEVER have to worry about that problemEven with negative camber, distance between your wheel and your knuckle/trailing arm does not change..
Anyways, for 8" wide wheels, as long as the offset is lower than +50 (+48, +46, +44, etc), you will be just fine..What size tires are you thinking of running? Again, keep it lower than +50, and run 205 width tires or narrower and you'll do just fine..
Hope that helps!
Ronald
Originally posted by Ronald_Type-R View PostHe's talking about interference with rear trailing arms/knuckles bro...Running +15 offset, you will NEVER have to worry about that problemEven with negative camber, distance between your wheel and your knuckle/trailing arm does not change..
Hope that helps!
Ronald
1992 Honda Accord Coupe LX
