OEM Brake Upgrade: Version 2.0
    Well here goes:
    I started this new idea that i would complete a modification to my car before I started a new one. So i decided to try and complete my brake upgrade since its already underway.
    In 2005 I did the five lug swap and installed S2K rotors and calipers. Since then I was contemplating putting Spoon calipers on the setup but I really didnt want to spend $1500 on the setup. But I was looking around and the Acura TL Brembo calipers are relatively inexpensive. After a little research I bought a set along with some of the parts needed to install them.
    I havent installed them yet, b/c i need a larger wheel spacer since i kinda like my wheels and dont want to buy new ones. The calipers fit but the provisions for the mounting bolts in the knuckle will have to be enlarged since the TL bolts are 19mm and my car is 17mm. I will update this as I progress into the project.
    Old Setup:
    Test Fitment:
    I have a spacer in place (no wheel studs) here to test the fitment, but I will have to get a larger spacer since this set was a couple mils shy of clearing the caliper.
    Once this is finished I can finally get my car painted. I think.
    Nice Keep it up. Can't wait to C the finished product.
    Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
      Love to see more pics as you go. shiet i love the set up now actually.
      (129)Transactions and counting
        You've probably got the only set of calipers like those that is going to show up for sale. Good job on the swap though.
          wicked setup....so the TL has the same caliper orientation as the CB, as per the location of the bleeder valve?...sweet
          DEVOTE
          FS: Lokuputha's Stuff
            yeah the bleeders are in the correct position. i was going to finish it this week, but my internship is ending this week and i have been swamped with that, but i will have time to do it after that.
            The DC5/EP3 Type-R calipers are the same basic setup as these and you dont have to change brake lines since it uses a banjo fitting... of course you'd probably have to sell a kidney to get a set since they are JDM/EDM Type-R parts. The TL calipers parts are only $645-ish brand new, minus pins, bolts, lines and pads.
            S2k Rotors-$130 (2005)
            Odyssey Knuckles-$75 (2005)
            TL Calipers/new pads-$400
            Lines, bolts, etc...-$95
            HR Spacer-$120
            -ttl:$820
              HR Spacer-$120
              -ttl:$820
              Not bad I love that setup. Its different from all the others i have seen and it definitely looks good
              Maple50175 - you're annoying =P
              Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
              JoshM - Crotch rocket = chick magnet.
                sweet set up, i would go for extended lugs nuts
                  Looks sick, good luck with the setup
