Just finished up a full 5 lug conversion, new pads, rotors, calipers, SS brake lines. Got it all done, went to bleed it, no problems, seemed to get all the air out... Well after it was finished, we had a crappy pedal. It didn't really pump up, but stayed mooshy the whole time. So, since it wasn't that great before the 5 lug swap, we concluded that the master cylinder was bad.
So tonight, just a little while ago we get a new 1" master cylinder installed, bench bleed, brake bleed... Same Fing thing, soft pedal. We bleed it a good while after, used almost a whole quart of fluid. The fluid is brand new at the calipers and i have good pressure.
I cannot for the life of me figure out why we can't get a good pedal. This is a 92 ex car, so we already had discs in the back, so no proportioning valve should have been needed. It is an abs car though. Does something need done with the abs? it seems like it passes it right up when we bleed it with no problems.
If anyone has some insight to this, it would be mega appriciated. I really dont know what to do with the car. I dont want to go to the extreme of an adjustable prop. valve and new lines to bypass the abs. There has to be a way to cure it.
Thanks for reading guys.
