OK, so heres the plan: I was going to use 98 CL 2.3 hubs, my 90 wheel bearings (which apparently go together somehow), 98 Accord 4cyl rotors and 95 Accord V6 Calipers/brackets/pads on the front of my 90 Accord. My question is will all of this both right up and work properly? If not, what do i need to do to get the ROH done AND the V6 Calipers?
tricky question, roh and v6 calipers
Originally posted by vmchurchwell there's the problem then, cus if I want to do the ROH conversion i need the 98 accord rotors, and if i want the v6 calipers/rotors it can't be ROH. fantastic, looks like i have a choice to make then.......
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
care to explain? According to the sticky u can use either the CL or accord rotors, and im thinkin that neither will work with the V6 calipers. If there are other rotors that are ROH that will work with the V6 calpiers, please let me know. Otherwise im scratchin the ROH idea dn just putting the v6 brakes on.
Originally posted by seigneur_raydenThe 98 Accord rotors are NOT a MUST in order to do the ROH.
Parts that are proven the same:
4th gen front knuckle - 5th gen front knuckle - 98 CL 4 cyl front knuckle
4th/5th gen front wheel bearings - 98-99 Acura CL 2.3 front wheel bearings
98-02 Accord V6 front calipers - 98+ Integra Type R calipers
98-02 Accord V6 front rotors - 98+ Integra Type R front rotors
98-02 Accord V6 rear rotors - 98+ Integra Type R rear rotors
