No fluid in master cylinder and no pressure in brakes
    okay so i was driving home tonight and i notice the brakes gettin very soft. While stopped at a light i realize i could put my foot all the way down. I realize after driving a lil more that the parkin brake light came on. I pulled over and the master cylinder was empty. The brakes stopped the car but only after puttin foot down completely. I then filled it back up and drove another 40 km home and realize when i got home that it was nearly empty again
    What is happen, where should i start checkin and any other info would be good
    okay i just was looking at my haynes and it says
    Brake pedal travels to the floor w/ little resistance
    1. Little or no fluid in the master cylinder reservior caused by leaking caliper pistons
    2.Loose, damaged or disconnected brake lines
    This seems close to what i have goin on, would my calipers be gone at about 450 k
    450K....holy crap.
    Pull it into a garage or a parking lot. Jack it up. Fill up the cup. Pump the brakes. Look/smell for leaks.
      seems as the wheel cylinder in the drum is damaged/leaking
      they go for $30 a piece cdn
      how much do you think labour would be to change it
