NSX calipers on a 5th gen.
    Anyone have NSX calipers on their 5th gen Accord? I'm trying to find out which caliper brackets and rotors I would need to install these calipers.
    Only one purpouse.....to go FASTER!
    0-60MPH: 15.2 sec
    1/4 Mile: 9.54 min
    60-0MPH: Too damn long!
    MUD ~ out
    For rotors you'll need to wagon rotors or do the rotor over hub conversion and use prelude VTEC rotors.
      Rotor over hub.
      Will I need the Prelude hub, or the CL hub for this? What size rotors do the wagons & AV6s come with?
      0-60MPH: 15.2 sec
      1/4 Mile: 9.54 min
      MUD ~ out
        11.2 I believe. I am running legend 2 pots and AV6 rotors under my stock EX wheels.
          just a side note, not a lot of people here have 5th gens
            You can use 23T brackets which came on the Vtec Prelude (93-96) and use the same Preludes rotors. The First gen CL's hubs also.
            If you don't mind the hub over rotor setup then you can use the 4th gen Wagon's rotors which are the same diameter and thickness. The 4th gen Wagon also uses the 23T bracket.
