Finally got my rear disc brake conversion
    I paid $200 for complete conversion including rear strut assembly and sway bar
    picking it uP
    trying to figure how i'm gonna fit it in my mazda. The trunk was full
    F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
    Finally home. The rear strut assembly and sway bar will be for sale. Me and Will(96jdmaccord) will be installing it today and will have a picture by picture DIY review on it later today
      Looks good man
        not bad, but you dont need the trailing arms.
          You need the rear crossmember in order to properly use the sway bar.
          Don't forget to pick-up a 1991 CRX Si or 1990-1993 4 wheel disc brake non-abs Integra proportioning valve.
            Where is the proportioning valve located on CB7's and could you post up a pic of it
              On the base of the firewall under the master cylinder, a little to the right of the steering shaft exit. You'll notice it has all the brake lines going to it.
                finished result, with my friend under my car LOL
                  Looks good. I want to do it soooooo bad. I envy you.
                  "I'm out for presidents to represent me"
                    That is very cool that you have 4wheel disc now. I remember that I hated having drums on my 90. Was thrilled when I bought my 93 and I finally had 4wheel disc brakes! ABS is cool to have as well.
                    "the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
                      i just did my conversion from drum to disc i have a problem with the pedal it keeps going to the floor do i need to change the master cylinder from a accord with rear disc holla at me ASAP
                        do i need this or a 4 wheel disc accord master cylinder for my accord that i just did the rear brake conversion
                          Accords with rear disc have larger bored brake master cylinders, different brake boosters and proportional valve. I have heard you can use 90-93 integra w/rear disc proportional valves
                          BTW I know this cuz I both compared parts on www.hondaautomotiveparts.com and cuz I have two Accords at home
                          91 SE w/rear disc
                          90 EX w/ rear drum
                            You don't NEED it but it would be nice. The larger bore of the EX brake master cylinder builds torque faster which translates to less pedal travel. But to answer your question, No, you don't need it.
