hmmm..i recently did a switch on my pads... now i put some abs fluid back in the main resevoir..but i now my brakes dont work....i also took off my calipers completely and painted them silver with ceramic...one of those autozone kits......the brake sensor is not indicating low fluid..and when i look in the resevoir there is plenty of fluid?? im thinking it had something to do when i compressed my caliper pump so my new brakes could fit....well this is my 1st time doing this...so im just gonna hit the store up and grab some more fluid..but it has a lot in the main resevoir...ive been pumping my brakes..and i tightened the calipers back down im guessing it has something to do with bleeding air out the brake lines..but im unsure....??
brakes not working
Originally posted by 93EXaestheticim guessing it has something to do with bleeding air out the brake lines..but im unsure....??-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-2012 GMC Canyon V8 4x4
thanks..! im gonna go get another set of jacks from autozone...while i have my chick push the brake pedal...now i dont recall seeing bleeding brakes in my chilton manual...is the bleeder screw that nipple that sticks out? what do i need to loosen that a philllips?.. well ill take a closer look in the morning..thanks!
Originally posted by TypeGget a haynes manual. any time you open a brake line you have to bleed it. later.
