Alright, new question. I got the brembo drilled rotors and axxis ceramic pads on fine, but now the pads rub the rotors whenever i turn the wheel. Granted i just finished so they might need to be broken in. Is that the case or did i screw up??
help!?
im no brake expert, but the pads rubbing while turning just doesnt sound right to me. do you mean the calipers rubbing or the rotors rubbing?!.. IDK i think you might need to redo the brakes.. and did you do the break in properly?! i know you have to softly apply the brakes for almost 500yds or something.. heating them up so that they seat properly. hopefully someone else with more brake knowledge can help you with your rubbing issue though. sorry i tried. good luck!
did u check the backing to the rotor that might be the rubbing noise and also the brakes sometimes will rubb till the set in and check the backing plate that will rub when u turn u might of hit it when u where doing the brakeswhen u first start off with new brakes and rotors try not to stop on the tap them or i mean pump them off and on when about to come to a stop off high way but best guess is backing plate push it back
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
