My brakes make super-high pitched squealing noises going forward, and increasingly loud groaning noises going in reverse. They also shake when I brake from speeds above 50mph...this problem started last week and got worse very quickly. To further complicate things, I just found out I have wheel locks on the car, but alas, no keys to unlock them...so it looks like I'm gonna need new hubs, possibly new rotors, definitely new pads, and if my luck is good new calipers too. I'm taking it in to be fixed tomorrow, so should I ask them if I can get 1st gen Legend brakes? What do you think the problem is? Right now my car stops worse than my mom's RX300, which is a major problem...
Brake woes and whines
Hey if its that bad it could be noises that could be the brakes change indicator letting you know they need changing at some point when the material is getting somewhat near the end it will let you knwo its going to need changing by brief squeels when coming to a complete stop.
But if you hear grinding noises as well you may have damaged your rotor real bad any damage is goint to need changing you cant put the new brakes back on a fucked rotor its just gonna eat the brakes defeating the whole puprose.
The best thing I can tell you is take the wheel off and inspect the braked very carefully the outside as well as inside all four of em if you see little mettal shavings that could be a sign too of a grinded down rotor. Like i said and ill say it again people maintenance ,maintenance,maintenance . Take care of your car and shell treat you like a king.
moved to brake performanceWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
