Considering some Brembo slotted & drilled front rotors.
    Well I'm certain my rotors are warped and rusted to shit, when I try to stop from 70 I get the meanest vibrations.
    So I was thinking of getting some brembos' that are drilled and slotted. Now I've been reading that drilled causes loss of heat which translates to loss of braking power. I can't understand this, why would they be called "performance" brake rotors if they'd have less potential stopping power? I've found the brembos' for 100$ shipped on eBay and my friend's father will help me put them in.
    Anyhow, I wanted to use Axxis Ultimate or Metal Master or EBC Green brakes pads. Think that is a good choice?
    Also, for added brake performance I plan to do a rear disc swap (courtesy of Patastinky) and utilize the 40/40 integra prop. valve (trying to find one).
    '93 Bordeaux Red Pearl LX 5MT
    Prev CBs:
    -'93 BRP LX 4AT
    -'92 AGP LX 5MT
    -'93 AGP EX 4AT
    10yrs after my first cb, I'm still driving one!
    Also how do I know what calipers I have, akebono or nissin?
    Remember it is a 93 LX without abs (I think..)
    Prev CBs:
    -'93 BRP LX 4AT
    -'92 AGP LX 5MT
    -'93 AGP EX 4AT
      check the calipers if it says nissin its a nissin if it has a triangle shaped deal its akebono.. by the way i have brembo xdrilled/slotted rotors for sale for a nissin with brembo sport pads if you want them hit me up
      Beast: Evo X
      Daily: 93 Accord LX Wagon
        how much and how used are they?
          I already got dibs via aol instant messenger
          Just need to find out whether I have nissin or akebono calipers.
          Prev CBs:
          -'93 BRP LX 4AT
          -'92 AGP LX 5MT
          -'93 AGP EX 4AT
            you got your info wrong. drilled does cause loss of heat but it translates to LESS brake fade which translates to an INCREASE in braking power. personally i would stay away from drilled because they are more prone to cracking around the holes. this is because they are literally drilled into a blank brembo rotor. this affects the integrity of the metal thus making it a bit weak. race cars have rotors that are casted with the holes meaning the holes were never acutally drilled into the rotors. i would go with slotted!
            as far as pads go, it's all based on preference. i have AEM pads, made by nissin. they are very good for the driving that i do (mountain roads). i've heard some certain pads actually eat the rotors ! just try any set of pads and see for yourself.
            you will prolly benefit the most from your rear disc swap. the braking is more even especially with a 40/40 prop valve. converting to steel braided brake lines also aid in removing that slushiness that you feel when stepping on the brake pedal.
            good luck!
            edit: i have a 92 LX and i have nissin front calipers. some might be different so just double check to make sure you have the right caliper.
            1cor10:31
            - 92 LX coupe
            - 96 EX wagon (sold)
              Now I've been looking at my rotors through the spokes on my 02 SEs and I cant seem to find any markings except for something that looks like a /\/\ sign. I'm leaning toward akebono.
              Thanks Timmy, btw my aim is Br0nx Finest, so hit me up I've got a few other questions to ask you about your brake setup!
              Prev CBs:
              -'93 BRP LX 4AT
              -'92 AGP LX 5MT
              -'93 AGP EX 4AT
                http://www.cb7tuner.com/vbb/showthread.php?t=17261
                that thread has pictures of the calipers. You actually have to take off the wheel to see the markings. good luck.
                  for the most part, I think the coupes have nissin calipers... which I dont like any more, since they are a much more crappy design. hence the reason Im swapping back to akebono.
                  I would skip out on the drilled and slotted, they are just for show unless its a big brake kit, or high quality stuff. Just get some nice ones from www.cobaltfriction.com, they are high quality and wont rust.
                    I utilized oem style braking for now, would like to save some money right now, so I can do other things and turns out these are good.
                    I used oem style rotors from strauss (40$) and Bendix ceramic (lifetime warrenty 35$) and paid 100$ for their installation. Not bad imo. Stops great, nice stainless steel looking rotors (not really, just look clean and silver).
                    Prev CBs:
                    -'93 BRP LX 4AT
                    -'92 AGP LX 5MT
                    -'93 AGP EX 4AT
