Done the fronts with rl. what can be upgraded on the rear discs ?
rear brake upgrades?
Going 5 lug? There are a few threads on 5 lug upgrades already. A little info will get you better answers. Are you looking for bigger 4 lug rotors or 5 lug?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by 8ball View Postim not going to lie to you dude, i didnt even know rl rotors and caliper brackets could be used on the 5 lug conversion.
Let us know how it goes man.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
Dang. U gotta post a pic.**Blk Housed Slut Crew Member #1**
There's not much information on what can be done for the rears. There are so many variables when it comes to rear hub/bearing dimensions on 5-lug Hondas that it borders on absurd. Flange height, flange diameter, inner race diameter and other factors all come into play here so there is no cut and dry answer...yet. There are aftermarket options, though.
Keep in mind that unless you proportion it properly read brake upgrades are an exercise in pointlessness, mostly.
Also, when you refer to your brake upgrade, I'm sure you're saying that you have the caliper brackets and rotors from a '99-'04 Acura RL. It's best to clarify as the '96-'98 are 11.1" rotors with 28T brackets unlike the newer ones that use 28mm thick 11.8" rotors with proprietary brackets. It eliminates confusion.
Anyone seeking pictures for the fronts can find them in the thread I posted about the rotor upgrade a while back.
http://www.cb7tuner.com/vbb/showthread.php?t=193862Last edited by Jarrett; 12-19-2012, 10:42 AM.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
