i upgraded to ss lines from goodridge and some ate super blue brake fluid. i drained the whole system. put in the lines and refilled the system with the ate and bled them until no bubbles came out on all 4 corners. also followed the haynes procedure on bleeding them.. left rear-rightfront-right rear-leftfront. but the pedal travel is way worse then what is was before. how is this? there are no leaks i already checked... give it time? anyeone has any ideas?
brakes suck after ss lines and racing fluid!??!
did you bench bleed the master cylinder? since you drained the whole system I would think that you need to bench bleed the M.C. as well
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
Because regardless of what haines said you almost always bleed form the farthest away valve. It should go like this PR, DR, PF, DF. make sure you didnt drain the master cylinder resavior of brake fluid thus sucking air in the system. The bast way to do this is to fill your resiover until ALMOST completely full then take another bottle of brake fluid and open it turn it upside down then stick it in the resiovor. This will insure you wont run out of fluid and suck air back in. Of course this only works of your using brake fluid that comes in a bottle with a skinny neck. Also not to call you ignorant or anything cause im sure your not but use two people that way one can keep pressure on the pedal and system and make sure your pushing the air bubbles out. Try that out and get back to us with the results im pretty sure youll be satisfied.
P.S. you only need to bench bleed the master cylinder if you replaced otherwise by refilling the resiovor you should be able to force most the air thru the system. Again remember to keep an eye on the resiovor.Last edited by 90AccordSiR; 03-18-2005, 07:15 PM.
I am having the same problem... brakes were perfectly fine before I did rotors and pads, and then they felt like the master cylinder was trash. Replaced Master cyl, bled the crap out of everything including master cylinder(bench bleeding) and they feel exactly the same as before. Im getting quite sick of the little random problems
well see i had 2 people when i did this. i was at the bleeder and my girl was at the pump. she pumped i opend the valve and bubbles came out and i closed valve and re did that plenty of times till everything seemed fine. as we were doing this i kept on eye out for the reservoir and i kept the fluid at max cuz it kept on going down of course cuz of the bleeding. so yea im not that igonorent. i have bleed my lines before and seemed to be able to do it. but i have never drained the whole system and put new fluid in. so should i changed the order of the bleeding pattern? and what is bench bleeding the master cylinder?
Bench bleeding is what you do off the car when installing a new MC. You bleed it in a vise, so you can get all the air out. Which is pretty much impossible on the car. If you wanted to, you could try to re-bleed it doing the above mentioned method. pr, dr, pf, df.
I think you did it fine, there is also someone else that has had this problem for a year or so, and is still puzzled as to what it it.
the master cylinder.. is there supposed to be a black rubber washer thing sitting at the bottom?
My old one that I took off didnt have one in it, and the one I had sitting around did, so i threw it in there anyway. Anyone else have one of these in there?
I am also thinking about pressure bleeding the system so it should shove all the gunk and crap out for sure.
Originally posted by aero3685Bench bleeding is what you do off the car when installing a new MC. You bleed it in a vise, so you can get all the air out. .What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
they have been getter thruough out usesage so i dont know. still not to a standard i wanted them to be at. still takes about half way for the brakes to grab.....umm could it be my brake pads? cuz i just got some powerslots rotors and axxis metal master pads like a month ago or so. and i noticed the braking sucked and i told myself well maybe cuz the mechanic didnt bleed the brakes so thats why.
I had the same problem as you. So I replace my rotors, pads, calipers, booster and mastser cylinder and still it was the same. Then I thought my drums were bad and then I did a rear disc converion and still the same. Moral of the story Perpotioning Valve. After all of that time and money a piece of foil from the brake fluid bottle got stuck in PV and was preventing air to bleed out of the front passenger side BL.
